Joburgtaxi
Installation path
Hi
I would like to install the files from my installer into an existing path however the path may be variable from computer to computer but the path needed per computer is available in the registry.
How can I make the installer go and pre fetch this path from the registry and make this the starting point for the install and then install the files to a sub folder of this predefined path ?
Drryn
Re: Installation path
Hello Drryn and welcome to Advanced Installer forums,
In order to retrieve the related path from the registry you can create a registry search operation in the Search page of Advanced Installer. Use the [ New Search Wizard ] toolbar button, to set up a new search, following step-by-step directions.
The property (by default it is RESULT_PROPERTY) that is assigned to the search operation will contain the value found in the registry. If registry is not found, then the property is empty.
Please note that during installation you can set the APPDIR with the result of the search operation.
For example, you can use the predefined Set installer property custom action to set the APPDIR. Note that you should add the custom action after the paths Resolution stage from the Wizard Dialogs Stage. Also, you should condition the custom action execution, something as below:
SetPropertyCA properties.png (36.87 KiB) Viewed 1824 times
