Antarctica
Problems with properties
In Advanced Installer 12.6.1, I have massive problems with properties.
I have defined properties that have a default value.
Like so:
I have not changed the OpenParen/CloseParen properties anywhere.
Yet, when I define a text file update:
[OpenParen]
	"": [OpenParen]
		"databases": [OpenParen]
			"timeflex": "user id=[CONNSTRUSER];password=[CONNSTRPASS];server=[SQLSERVER];database=[SQLDB];connection timeout=10"
		[CloseParen],
		"exchange": [OpenParen]
			"privilegedUserName": "[ADTIMEFLEX]",
			"privilegedUserPass": "[ADTIMEFLEXPWD]"
		[CloseParen],
		"jobs": [OpenParen]
			"dispatcherGroup": [OpenParen]
				"dispatcherJob": [OpenParen]
					"class": "DispatcherJob"
				[CloseParen]
			[CloseParen]
		[CloseParen]
	[CloseParen]
[CloseParen]
The resulting file is:
Property.OpenParen
	"": Property.OpenParen
		"databases": Property.OpenParen
			"timeflex": "user id=;password=;server=sqlserv2;database=tf150;connection timeout=10"
		Property.CloseParen,
		"exchange": Property.OpenParen
			"privilegedUserName": "timeflex",
			"privilegedUserPass": "test"
		"jobs": Property.OpenParen
			"dispatcherGroup": Property.OpenParen
				"dispatcherJob": Property.OpenParen
				Property.CloseParen
			Property.CloseParen
		Property.CloseParen
	Property.CloseParen
Property.CloseParen
The verbose log tells me that the default values of CloseParen and OpenParen are not set correctly.
Property(S): OpenParen = Property.OpenParen
Property(C): OpenParen = Property.OpenParen
Furthermore, the verbose log tells me that [CONNSTRUSER] and [CONNSTRPASS] contain values, although these values are no longer set correctly in this file and also no longer set correctly in an XML update (the latter worked before I added the new text file update):
Aktion gestartet um 17:50:07: ReplaceConnectionString.
MSI (c) (C4!98) [17:50:07:808]: PROPERTY CHANGE: Adding CONNSTRUSER property. Its value is 'sa'.
MSI (s) (6C!E8) [18:05:27:837]: PROPERTY CHANGE: Adding AI_TxtUpdaterConfig property. Its value is 'ProductCode{CFD37785-EA7C-44CE-95EA-F0B04BA80BA3}RollbackDisabledAI_TEST_TXT_UPDATE_FILE_NAMEAI_TEST_TXT_UPDATE_DIRECTORYindex.htmlAI_ExePathindex.htmlC:\inetpub\wwwroot\timeflex\timeflex\17cache.appcacheAI_ExePathcache.appcacheC:\inetpub\wwwroot\timeflex\timeflex\17YourFile.txtdefaultplainscrollbottom.png_1config.jsonC:\inetpub\wwwroot\timeflex\Service\25index.html<html><html manifest="cache.appcache">00-1cache.appcacheCACHE MANIFEST
# TIMEFLEX 1.5.0
CACHE:
index.html
app.js
NETWORK:
*16001YourFile.txtProperty.OpenParen
			"privilegedUserPass": "Aktion 18:05:27: AI_TxtUpdaterConfig. Textdateiaktualisierungen ausführen
Aktion gestartet um 18:05:27: AI_TxtUpdaterConfig.
AI_TxtUpdaterConfig: Aktualisiere Textdatei: "Textdateiaktualisierungen ausführen"
So it seems
- the default value of predefined properties is not set correctly and
- properties can lose their values during text file update
Antarctica
Re: Problems with properties
It seems the issue has been caused by adding an unused dialog and has been fixed by removing that dialog again.
I'm glad you got this working by yourself. Also, thank you for your follow up.
If you have other questions, please let me know.
