vigyanlabsmys
Translation problem in Korean Language
In folder dlg page the text "Next" and "Browse" is not getting translated in Korean Language. Attached Screen shot PFA
AD installer version we are using is 11.6
Best Regards,
Re: Translation problem in Korean Language
Indeed, this is an Advanced Installer mistranslation. I updated it and it will be available in the next version of Advanced Installer. Thank you for bringing it to our attention.
Meanwhile, you can go in the "Translation" page, "Default Strings" tab and update the translation on the Korean column of the "Control.Text.FolderDlg#Text" row.
vigyanlabsmys
Thanks for your reply... Now its working :)
Best Regards,
You're welcome. I'm glad it works.
