prasanth.tech
Issue with shortcut in windows 10
I have seen a strange behaviour with regards to shortcuts, when installing an Installer created with AdvancedInstaller on Windows 10 x64 platform.
I have added two shortcuts (in below locations )to same exe using "Files and Folder" view in IDE.
1. Start Menu
2. Start Menu>>Programs>>MyApp
This above adding causes three shotcuts (extra C) to appears in Windows 7 OS, even though I added only two. But this is not causing any issues for me in Windows 7.
A) In Start Menu
B) In Start Menu>Programs>MyApp
C) In Start Menu>>Programs
But in Windows 10, I can not see shortcut to exe under "Start Menu>Programs>MyApp". In my analysis It is found that, if I manually delete one from "Start Menu>>Programs", it comes correctly for B. This additional shortcut creation ,as in C, causes issue in Windows 10.
Please share your thoughts on this scenario.
Prasanth
prasanth.tech
Re: Issue with shortcut in windows 10
I would like to refine my above question after my further analysis.
The issue seems to be with Windows 10, not AdvancedInstaller. Anyway, I am just writing it here, if anybodu have seen this issue before, pls share your thoughts.
On Windows 10, the shortcut to Start Menu>> All apps>>MyProduct is missing ONLY if another shortcut with same name and to same exe is present in the folder "C:\Program Data\Microsoft\Windows\Start Menu\". In Windows 7 there is no such issues.
Prasanth
Hello Prasanth,
As a follow up to your post, I can confirm you that this is the default Windows behavior starting with Windows 8.1 OS. When installing in "ProgramMenuFolder" (i.e. C:\ProgramData\Microsoft\Windows\Start Menu\Programs) two shortcuts targeting the same resource (file, folder, etc) only one shortcut will be displayed in Apps screen.
prasanth.tech
Thanks you very much for your reply!
You're always welcome.
