hsc
Enterprise license required?
AI keeps annoying me with messages that say an option is only available in the Enterprise version. The point is that I have an Enterprise license. Any additional options I must set? This is AI 12.8 (Help/About is attached) on Windows Server 2008R2.
Help/About
Help/About
2016-04-19_09h26_14 - Copy.png (21.67 KiB) Viewed 4820 times
Error message
Error message
2016-04-19_09h25_41 - Copy.png (9.76 KiB) Viewed 4820 times
Error tooltip
Error tooltip
2016-04-19_08h42_13 - Copy.png (4.54 KiB) Viewed 4820 times
Re: Enterprise license required?
Those messages are displayed if you created a lower project type (i.e. Professional). In order to upgrade your project to "Enterprise" you can use the "Options" toolbar button, then go in the "Project Type" tab.
hsc
Thank you Eusebiu, that was the key. I converted the project to "Enterprise" and now the annoying messages are gone. However, unfortunately the "Maintenance Command Lines" section with its options (see the last screen shot of my original post) are also gone. The effect is that the prerequisites (VC++ run-time) which are installed during install are not removed during uninstall.
You're welcome.
The "Maintenance Command Lines" section is not available for the "pre-install" prerequisites. So, you can add your prerequisite in the "feature-based" folder if you want to have those options available for it.
hsc
Ah that does the trick :-)
