vijaya_st
file was Currupt (wrong MD5 Signature)
Hello team
I am trying to install update which is created using advance installer update,but if i uploaded exe file to dropbox and provide installation URL of Dropbox file then it gives error "file was Currupt (wrong MD5 Signature),but if i upload exe file to any other location instead of dropbox it is working successfully.
so what is the problem with dropbox location ?can you please help on this point.
Re: file was Currupt (wrong MD5 Signature)
Please make sure that you give the direct URL to the file, not to a web page. When you use that URL in a browser (i.e. Chrome), does the download of the file starts automatically or a web page is displayed?
A Dropbox link points directly to a file when the parameter from the end of the URL is "dl=1". Can you try this and see if it works?
cf454
I am getting the wrong MD5 signature error on a few installs, not all, running the updater from a website url.
Please see attached.
The MD5 box in the updater project IS checked.
Any suggestions?
Thank you!
wrong md5.png (18.99 KiB) Viewed 3608 times
In order to have a better view of this problem, can you please send us your AIP file and the Updates Configuration project to support at advancedinstaller dot com, so we can investigate them?
