Zsolt Kollarits
Prerequisite installation dialog shows wrong text in the version column for .Net 4.6.1
Our prerequisite installation dialog shows wrong text in the version column for .Net 4.6.1 prerequisite. Here is the exact text: "Required: any. Found: nothing.".
All the texts of our other prerequisites are just fine. Another support thread of yours is talking about a similar issue, please find it under:
http://www.advancedinstaller.com/forums ... php?t=7551
From that thread we know that the Prerequisite/Properties/Display section should be filled in as it delivers the information to the prerequsite dialog. Due to this always put proper texts into those fields, all of our prereqs are configured in the same way and apart from the .Net 4.6.1 item all of them look good - showing proper version numbers - in the prereq dialog.
Could you please check the screenshots I attached to this post and advice me something?
Zsolt Kollarits
prerequisite version message is incorrect.png (27.71 KiB) Viewed 3968 times
.Net Framework properties display section.png (5.3 KiB) Viewed 3968 times
.Net Framework install conditions window.png (17.32 KiB) Viewed 3968 times
Re: Prerequisite installation dialog shows wrong text in the version column for .Net 4.6.1
Hi Zsolt,
Thank you for your intensive feedback.
Unfortunately we cannot display the same UI for .Net Framwork becuase the install condition are different for these prerequisites.
Note that the the criteria for the install condition of the Visual C++ 2010 SP1 x86 (MFC Security Update) prerequisite is Registry value containing a version, as you can see below:
VisualC++ instal criteria.png (26.81 KiB) Viewed 3963 times
while the search criteria for Net Framework is Registry value with specific content, see below:
NetFramework - instal criteria.png (26.36 KiB) Viewed 3963 times
This is why we do not display the same UI for these prerequisites.
Zsolt Kollarits
Hi Dan,
Thanks for your letter, your screenshots were really helpful, we managed to sort this issue out!
Zsolt
That's great news Zsolt,
