ajvpr
Removing "Buy" option from initial trial license window
I would like to remove the "BUY" option (3rd option) in the main license window. Is there some configuration that I could tweak to make this happen?
Just to be clear, I want to have just 2 options on the main trial license screen: "Try" and "Register".
Thanks!
Re: Removing "Buy" option from initial trial license window
To edit the trials dialogs you need to edit the Trialware.aip fragment from the internal resources of Advanced Installer (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 12.7.2\fragments).
If you only want to remove the Buy option from the trial welcome (see above image), then you can remove the Buy control from the control list. e.g.
localize the following row in the trialware.aip:
<ROW Trialware="alltrials" Section="TrialPage" Key="AeroCtrls" Value="Msg Try Register Buy Cancel"/>
and remove the Buy control. Note that you should have the following row after this operation:
<ROW Trialware="alltrials" Section="TrialPage" Key="AeroCtrls" Value="Msg Try Register Cancel"/>
Note that you need to reload Advanced Installer and rebuild your project so that the changes take effect.
Let me know if you need any help.
