cf454
Wrong MD5 Signature error on update
Hi Guys,
Some of my users are getting the file was corrupt wrong MD5 signature on update (the updater points to a url on a server and doesn't update fine on most machines).
It's downloading the entire msi and then when it starts the install it gives the error.
The MD5 box IS checked on the updater project. I attached that.
Any suggestions? Thanks!
7.0 Updates.aip
(1.72 KiB) Downloaded 549 times
wrong md5.png (18.99 KiB) Viewed 3536 times
Re: Wrong MD5 Signature error on update
This may happens if you manually changed the ;aiu file or the .MSI has been changed after the ;aiu file has been created.
Please make sure that you create the ;aiu file using the Updates Configuration Project template as you can see in the updates file tutorial.
Let me know if the behaviour still persist when using the recommended approach.
