mathieu
LaunchFile custom action doesn't accept path that include spaces
I'm trying to call a bat file from a Custom action right before the "Finish execution" step.
find attached the screenshot of this custom action config.
Here is what my dummy script looks like :
echo %1
pause
if I pass [APPDIR] in the 'command line' field, it echoes "C:\Program" when installed in "C:\Program files(x86)\Your company\Your application\"
So it stops at the first space.
I tried double-quoting the command line parameter -> "[APPDIR]" but then my script fails without echoing anything and the installation rolls back.
Any idea what's happening and how I can pass a path containing spaces?
Thanks.
NB : I'm using AI v12.8
Capture d’écran 2016-05-04 à 11.38.14.png (51.68 KiB) Viewed 3803 times
Re: LaunchFile custom action doesn't accept path that include spaces
This is indeed caused by an Advanced Installer limitation of our "Launch file" custom action type. The issue is caused by the "Run as administrator" flag. To achieve what you want just uncheck the "Run as administrator" flag and enclose between quotes the [APPDIR] property reference from the "Command Line" field.
We'll try to improve our "Launch file" custom action functionality regarding this scenario in a future version of Advanced Installer. We'll update this thread when an improvement will be out.
mathieu
Thanks for the tip. It worked just fine.
You're always welcome.
