karthick.k
Restart message at the end of each install
Recently, we have made some minor changes in our installation project, from that point we are getting Restart message at the end of each installation.
Earlier we are not getting this message. So we are not sure what made the installer to trigger the message.
Can you please assist us to understand this.
I have attached the screen shot of the message and please download the installer log from the below link.
https://drive.google.com/file/d/0B0RTDi ... sp=sharing
2016-05-06 19_35_50-Clipboard.png (16.72 KiB) Viewed 4416 times
Thank you
Re: Restart message at the end of each install
As I can see in the log, the MsiSystemRebootPending property is set.
MSI (c) (E0:60) [18:55:22:522]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
The installer sets the value of the MsiSystemRebootPending property to 1 if there is an operation pending to rename a file.
Also, in the log I can see that:
Info 1903. Scheduling reboot operation: Deleting file C:\Config.Msi\190e653.rbf. Must reboot to complete operation.
For details, please check the Insights into the underlying Windows Installer reboot behavior article.
Note that a file is held in use:
Info 1603. The file C:\ProgramData\iRely\i21\SqlDacRuntime\InstallFunctions.exe is being held in use.  Close that application and retry.
To detect if a file is in use and close it, please follow the steps from the How to detect or stop a process? article.
Let me know if that helped.
