MLiss@Cetrus.com
Read registry value for path
I have an installer built for application "A" - let's say the application gets installed by the user to "C:\A\bin"
I have another installer built for my plugin "P"
I was thinking about setting a registry key in HKLM under my company key and using the "APPDIR" install property of "A" to set as the base install directory of "P". So "P" would be installed in "C:\A\bin\P" ( see attachments )
I would like to use the FolderDlg "Init Events" somehow to set this path and then make it read only... ( see attachment )
How can I read the value of the registry key during the installation of "P"
Re: Read registry value for path
Hi Mike,
To achieve this you can, indeed, write the "A" application folder to the registry during the installation, then create a registry search in the "P" package that will get that registry value and use a "Set installer property" custom action to set the search value to the "APPDIR" property as in the following example:
  • Property: APPDIR
    Value: MY_SEARCH
As you mentioned, you can set the "Path Edit" field from the "FolderDlg" dialog of the "P" package to read-only.
MLiss@Cetrus.com
I guess I was not clear enough..
How do I "create a registry search in the "P" package that will get that registry value" ?
That's the part I am stuck on... where do you have a registry search function in the installer?
Mike
MLiss@Cetrus.com
Hello again,
I dug around and found the "search", made one and hooked it up like I thought it was supposed to run.
I will attach snap shots of my results
MLiss@Cetrus.com
Searching the registry
MLiss@Cetrus.com
Testing the registry search:
MLiss@Cetrus.com
Edit box "Init Event"
MLiss@Cetrus.com
Edit box Init Event details:
MLiss@Cetrus.com
Testing the plugin install package
( picks up the right path from the registry )
MLiss@Cetrus.com
Error during install:
MLiss@Cetrus.com
NOTE: The c:\Temp\_Logs directory does exist on disk... but the Plugins\SoftwareInventory part does not... do I need to create that from the installer?
MLiss@Cetrus.com
I added the "MANAGER_INSTALL_DIR" to the Files and Folders... but it did not resolve it
MLiss@Cetrus.com
Please see the attached log file
LogFile.txt
Log file with error
(47.02 KiB) Downloaded 631 times
Last edited by MLiss@Cetrus.com on Wed May 11, 2016 4:28 pm, edited 1 time in total.
Hi Mike,
The problem appears because the "MANAGER_INSTALL_DIR" value is assigned to the "APPDIR" property, but that value is not a valid path. The value of the "MANAGER_INSTALL_DIR" property should be assigned to the "APPDIR" property, not the "MANAGER_INSTALL_DIR" value itself.
You might have written that value in the "Install Parameters" page or in a "Set installer property" custom action. If you are not able to find it, please send me your AIP file to support at advancedinstaller dot com, so I can investigate it, too.
MLiss@Cetrus.com
Please review ALL of the snapshots I have provided.
The value of "MANAGER_INSTALL_DIR" IS A VALID path. The "Test result of the searches" confirms it
