raghu.00a@gmail.com
Edit Boxes Style
I created dialog with edit boxes in it.After the build successful, I can see the edit boxes are not appearing as the edit boxes that are in design dialog.
the edit boxes style is changed while run the project.
please suggest me how to create editboxes without any styles have applied?
Regards
Raghu
Re: Edit Boxes Style
Hi Raghu and welcome to Advanced Installer forums,
I'm not sure I fully understand your scenario. Can you please attach a printscreen with the encountered behaviour? e.g. how it looks in the designer mode and the encountered behaviour when running the installer?
raghu.00a@gmail.com
I attached the images in design mode and in running mode.you can find the highlighted text boxes and their design.
Regards
Raghu
Image while running installer
Image in design mode
Please note that the installer dialogs are handled/painted by the OS not by Advanced Installer during installation.
Maybe if you will enable the Enhanced User Interface you will get the desired UI for the dialogs.
