MLiss@Cetrus.com
ODBC Timeout problem
I am getting an ODBC timeout during install ( see attached images )
BUT I have NO SQL code in my installer. ( see attached images )
Mike
MLiss@Cetrus.com
Re: ODBC Timeout problem
Here is the install log file
ODBC_Log.txt
(16.19 KiB) Downloaded 286 times
Hello Mike,
Please note this is our default behavior. Even if your Sql query/script content is empty, if its install condition is true we still establish the ODBC connection with your SQL server using the parameters you configured for your SQL Connection and then we launch the SQL query/script without validating its content.
Also, the related timeout error is thrown when we try to establish the ODBC connection with your SQL server. It is not thrown because the query content is empty. An empty query produces no results, but the installation should continue.
Can you please make sure the ODBC connection parameters are correct? Usually this error is thrown when the Server name parameter is not correct.
