rdt
user define validation
im trying to add licencing to my installer using user define validation
i based on this tutorial to create the dll
http://www.advancedinstaller.com/user-g ... rp-ca.html
everything looks ok and i successfully build the project installation but when im installing it im getting "run dll access denied" (see picture below )
Re: user define validation
Hi and welcome to the Advanced Installer forums.
I tested the scenario, but I couldn't reproduce the problem. It seems that there is a permissions issue. Can you reproduce the behavior on multiple clean machines?
If so, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
This error usually occurs when the DLL file that should be executed by the custom action has been deleted. The file cannot be located since it was, mostly likely, removed by an anti-virus or an anti-malware software.
Can you try to disable the anti-virus and see if the problem persists? Were you able to reproduce the problem on more machines? If so, can you please send us a sample installer that reproduces the problem, so we can test and investigate it on our machines?
rdt
im having the same problem after disabling the anti virus
the dll hant been deleted
Can you please make sure your package validation DLL do really sets the "SERIAL_VALIDATION" property as it is explained in fist section of our "Developing a DLL for serial number validation" article?
