aeplengg
Application startup error
We have develop one package using AI. One of our client installs this setup.
After launching the tool he received following error.
After opening:
When he cancels:
Re: Application startup error
This behavior may be caused if you are using an advertised shortcut to launch your application or by the Windows Installer's application resiliency mechanism. When installing a file extension through our "File Associations" page, after installation every time your application tries to access/launch a file with the installed extension, Windows Installer will check the key files of all components residing under the same feature as the component of your installed extension. If at least one key file is missing, then a repair operation will be triggered for the above feature so that the features resource files be restored.
To avoid this issue, you can build an EXE setup with resources inside and check the "Do not delete extracted MSI and CAB files" option from "Builds page -> Configuration tab" of your setup project.
Also, please take a look on our "Why does Windows Installer ask for the original package during a Repair?" faq.
