t3knoid
EXE Passive install progress dialog
Our product string contains an ampersand (&) character. In dialog text controls where the string is used, I have to set the No Prefix setting to true. I am able to modify every dialog except for the one that shows up whenever the /passive is used. Where is this dialog located? I can't seem to find this dialog from the Advanced Installer IDE.
5-17-2016 9-29-22 AM.png (10.83 KiB) Viewed 3777 times
I was able to track down the string "Please wait while Windows configures [ProductName]" in the Error table. However, this table does not seem to be related to any Advanced Installer editable object.
t3knoid
Re: EXE Passive install progress dialog
Bumping this up.
I just need to know if this is possible so I can note it on our bug base that this (ampersand not displaying properly) behavior is as expected. Thanks.
First of all I apologize for my delayed reply. We are a bit stacked at the moment.
Unfortunately we don't offer support to edit the related progress dialog. However, as a workaround you can edit the error text you already found out in "Error" table like this:
Please wait while Windows configures Your&&Application
Just go to "Table Editor" page (available only in an Enterprise project type), select the "Error" table and edit the above message similarly.
t3knoid
OK. That is what I figured my option is. Thanks for confirming.
You're always welcome.
