MLiss@Cetrus.com
Updater File path
I am creating an updater and would like to know what is the reason for the "file path" ( see attached ) if the updater is going to a URL for the binary? ( I assume it is the "Installer Download" listed as the "Main URL" )
Re: Updater File path
Hello Mike,
This field is used only at build time to access the EXE updates setup. The updates setup file need to be accessed at build time so the Advanced Installer compute its MD5 integrity checksum, its file size, etc. when building the updates configuration file.
So, this "File path" field is useful for the Advanced Installer application at build time (when building the updates configuration project) to access the updates setup file. The updates setup file is not accessed at build time from the URL location because there might be situations when the build machine doesn't have access to the web server were is hosted the updates setup file. This is why we created this field to allow the user building the updates configuration project by accessing the updates setup file directly from the local build machine.
MLiss@Cetrus.com
You're always welcome.
