vigyanlabsmys
Uninstall popup
On uninstall button click in control panel, a popup message will appear. In that cancel button will appear and I want to disable that cancel button during uninstall (attached screen shot PFA).
How to do this?
Cancel button.jpg (30.3 KiB) Viewed 3779 times
Best Regards,
Re: Uninstall popup
I'm afraid this is not possible. The [Cancel] button is a built-in control in every MSI dialog and it cannot be disabled.
vigyanlabsmys
Re: Uninstall popup
Thanks for the reply. But our requirement is "Once the user clicks uninstall only progress bar should appear". So how to do this?
Best Regards,
Re: Uninstall popup
I'm afraid this is not possible either. The related uninstall dialog is a standard Windows Installer dialog and cannot be edited.
