karthick.k
File
While installing we do not want a file to be over written, so we have used the condition AI_INSTALL AND ( ORIGIN_INTEGRATION = 1 ). It looks like worked fine in Windows 7 and not in Windows 10.
You can download the log files in this link,
https://drive.google.com/file/d/0B0RTDi ... sp=sharing
Please advise.
Re: File
In order to have a deeper view of your installation project can you please also send us the AIP (project file) to support at advancedinstaller dot com and mention the name of the file which is overwritten, but it shouldn't?
karthick.k
Re: File
Hi Daniel,
Here is the details,
2016-05-24 13_06_03-BAMBOO Server- Remote Desktop Connection Manager v2.7.png
2016-05-24 13_06_03-BAMBOO Server- Remote Desktop Connection Manager v2.7.png (221.38 KiB) Viewed 5960 times
Please download the project files from this link,
karthick.k
Re: File
Hi Daniel,
Any updates on this?
Thanks.
Re: File
I've tested your installation scenario using a new project with similar settings like yours, but I cannot replicate at all the behavior. Can you please also forward us a download link to the setup package you built with the sent project so we can fully test it on our side too?
karthick.k
Re: File
Hello Daniel,
Do you mean, you need the complete files or the components used in the installer project?
karthick.k
Re: File
Hi Daniel,
Here is the components used by the installer project.
Please download it from the below link,
https://drive.google.com/open?id=0B0RTD ... VctVHNkbVk
Re: File
I would have need the EXE setup package built by you. However, I built your setup project using your sent resources and tested the built EXE setup package on a Windows 8.1 and on a Windows 10 machine, but I couldn't replicate the behavior. The file is always preserved (not overwritten). Please do also forward us a download link only to your built EXE setup which manifests the issue.
Also, it will be tremendously helpful if you could isolate the issue in a small buildable sample (AIP + its referenced resources) and send it us alongside a detailed step by step test case we can follow to replicate the issue on our side.
