mhubel
installed program requests permission
We are using version 12.6.1 to generate an installation. The installed program generates a "User Account Control" message on some computers (especially windows 7)". The message is attached. We have a digital signature from COMODO. What else is required?
Re: installed program requests permission
Please make sure that you correctly configured the digital signature certificate in the "Digital Signature" page (you must check the "Sign the package using" checkbox).
The information displayed on the security dialog (UAC prompt) is collected from the digital signature of the package. In this particular case if you set the Description field from the Digital Signature Page it will display the correct package name.
Let me know if that helped.
mhubel
It seems that I did not get a notification of your post.
These does not appear to be any check box "Sign the package using". I have attached the digital signature page for this project. Is this in some other form which I have missed?
The interesting part is that on other projects which don't even have the "enable signing" box checked do not generate this message.
I have been trying to avoid an upgrade until this version has been released but if absolutely required we can do the upgrade.
