MLiss@Cetrus.com
Invalid command line
Daniel,
I received notice that a newer verison of the manager is available for download.
When i selected download now, the manager update began. During the update a "Invailed compand line" error occured.
I have attached the Updater.aip for inspection.
Why would I get this error?
Manager_Updater.aip
(1.63 KiB) Downloaded 439 times
Re: Invalid command line
Hello Mike,
Did you build the "Manager.3.0.223.0.api.1.0.Setup.258.exe" updates setup with Advanced Installer? If so, then please note that the command line you are trying to pass to it is not correct.
/q /IACCEPTSQLSERVERLICENSETERMS /ACTION=Install /FEATURES=SQLEngine /INSTANCENAME=SQL_EXPRESS /UpdateEnabled=False
This looks like a SQL Server setup command line type.
You can find all the supported command line options of our EXE bootstrapper in our "EXE setup file" article.
MLiss@Cetrus.com
Daniel,
Yes I did build the Manager setup with AdvancedInstaller ( I love your product btw )
And yes that is a SQL server command line...
My question is how does that command line get called from your setup? ( it's in the manager setup - see attached )
SQL Prerequisite command line
MLiss@Cetrus.com
In addition, I already have an MSI command line... how does that affect the install?
see this:
Hello Mike,
Yes, the command line which the SQL Server prerequisite will be called with is stored in the main installation setup. There is no need for you to pass this command line at install time to the main installation setup file.
Our EXE boostrapper is a wrapper over an MSI installation database. So when you build an EXE package type the EXE bootstrapper will contain embedded (or next to it) an MSI installation database. At runtime the EXE setup launches its MSI. The option from our "Builds page -> Configuration tab" allows you to specify a default command line which the MSI will be launched with by the EXE wrapper setup.
If you have any questions or doubts just let us know.
MLiss@Cetrus.com
Thank you so much !
You're always welcome Mike.
