MLiss@Cetrus.com
Updater Product Version vs Expected Value
I have an updater and I am wondering how Expected value and Product Version are related and what values should I be using?
Mike
Re: Updater Product Version vs Expected Value
Hello Mike,
The Expected Value field contains the value that the Updater will look for (accordingly with the search detection type you have used) on the local machine in order to determine if the update should be installed or not. Usually, this is a registry search whose value is set at install time by the setup package to the ProductVersion of the installing setup. However, you can also define your own custom updates detection criteria.
The Product Version field should be set to the ProductVersion of the updates installation package. This field is redundant only for setup packages which have the "Check for updates before installation" flag set in their "Updater" page. If the ProductVersion from your updates configuration file is higher than the ProductVersion of the currently launched setup, then the updates setup package will be downloaded and installed.
