zonkzen
Prevent installation folder change when upgrading
As in topic - I would like to prevent the user from changing installation folder change when upgrading to a newer version.
I know on Upgrades there's 'Use original path when upgrading' and that works fine.
Any way to disable changing it?
Re: Prevent installation folder change when upgrading
In order to prevent the user to change the installation path when upgrading, you can disable the editbox and the browse button through the control conditions section. You can take advantage of the OLDPRODUCTS property. This property is set only in a package which upgrades another package.
For example, the control conditions can be something as follow:
Please let me know if you need any help.
zonkzen
Thank you for the answer!
If I'm not mistaken this is only possible if I would have a version higher than Professional, right?
Do you have any solution for Professional?
Indeed, you would need the Dialog editor feature that is available starting with the Enterprise edition of Advanced Installer.
Note that you can purchase an upgrade to the Enterprise edition of Advanced Installer on the following page:
http://www.advancedinstaller.com/upgrade.html
Please enter your license key in the field of the above page in order to see the available options. The price is roughly the difference between the two license types.
zonkzen
That's really a pity as my client is not planning on spending so much money just to prevent changing path when updating.
Isn't there any other way?
Alongside the "Dialog Editor" feature, the "Enterprise" edition of Advanced Installer also comes with a suite of powerful features like "Update XML files", "Text File Updates", "Patches", "Trials and Licensing", "Databases", etc. You can check our top "Enterprise" features or you can take a look on our full list of features by edition. You can purchase an upgrade to the Enterprise edition of Advanced Installer on the following page:
Also, since we always try to help our customers to get an adequate edition of Advanced Installer which suits for their needs, you can send us an e-mail to support at advancedinstaller dot com and if you are interested in an Enterprise edition of Advanced Installer maybe we can help you with a purchase discount.
