Ruben
Filling out both "Dialogs Stage Condition" and "Execution Stage Condition"
A Custom Action was doubled (with Shift-Drag&Drop). It is available in both Dialogs Stage and Install Execution Stage.
Now, the custom action has two conditions (instead only one), see the screenshot.
[img]
[/img]
How shold we use these two conditions ?
I'm asking because we want do fill the fields right before delivering ;-) Surely, there's a docu of the screen, e.g. here:
http://www.advancedinstaller.com/user-g ... rties.html but I missed the questionable part.
Thank you.
Ruben
Re: Filling out both "Dialogs Stage Condition" and "Execution Stage Condition"
Hi Ruben,
This is the normal behavior when a custom action is shared between Dialogs Stage and Install Stage. It is practically the same custom action added to both stages and each option you set for it on one stage will be automatically set to the one from the other stage.
In the two fields you can write a different condition for each stage of the installation. Also, you can click on the "Advanced execution scenario..." blue link and select the "Skip action in Install Execution Stage if executed in Dialogs Stage" option.
