ZombiesWithCoffee
Installing additional files to AI_ProgramFiles
I need to install a directory structure of xml files to the [AI_ProgramFiles][Manufacturer] directory.
I'm using "[AI_ProgramFiles][Manufacturer]\Enrollment" as the Installation Folder and that's perfect. This is a Mixed 32/64 Package and everything is working fine except for this one issue.
When installing these xml files, I want to install it at "[AI_ProgramFiles][Manufacturer]\XMLFiles". Notice that it's not in the application directory because these files will be used across many different applications.
When adding files via the 'Resources: Files and Folders" page, I can either install in "Program Files" or "Program Files 64", but there isn't an option for AI_ProgramFiles.
If I install them under "Program Files 64", then they don't install on a x86 system since that folder doesn't resolve.
If I install them under 'Program Files", then on a x64 system, they install to "C:\Program Files (x86)" and are now in a completely different folder than the application.
http://www.advancedinstaller.com/user-g ... types.html
So, how do I install additional files to the AI_ProgramFiles resolved directory?
Note: We're talking about 100+ xml files and directory structures and I really don't want to add/maintain two sets of files in the install.
Re: Installing additional files to AI_ProgramFiles
Please note that you can add the related .XML files in both places, "Program Files 64" and "Program Files". They will only be added once in the setup package. We automatically detect that the same files are used and we do not add them several times.
Let me know if that helped.
ZombiesWithCoffee
The good news is that it's exactly how I currently have it setup. It's a little bit of a hidden feature, but as long as it works. Thanks for the information!
You're welcome,
