kuradeel
Multilingual updates configuration proyect
I think I'm having a bad day, but I can't create a multilingual updates project.
We have allready deployed a multilingual app (installed with a multilingual advanced installer, based on the locale of the computer), now we want to launch an update but I can't select multilingual update project, because the option is disabled.
What is the proper way to do this? I was reading here, but I can't find the solution http://www.advancedinstaller.com/user-g ... tions.html
Re: Multilingual updates configuration proyect
When building an update configuration file with multiple languages, an updates configuration file will be created for each language. You cannot have a single updates configuration file, this is why the only option enabled is the Create separate packages option is enabled.
All you have to do is to link the Updater.exe to look for the corresponding update configuration file when searching for updates. So, in the Updates Configuration File URL field from the Updater page, you need to have a property (e.g. ProductLanguage property ) that will resolve to the corresponding path of the updates configuration file on your server, based on the selected language that the user selected for installation.
e.g.
http://www.example.com/download/[ProductLanguage]/updates.txt
Please let me know if you have any questions.
