DiegoCP
Dialog Button/Combos Background Color
i have a question regarding how to change the background color of a text item, as you can see in the image the background is currently black.
By i cannot seem to change it anyway.
I did some research and found that one of these tags in the .ini file is responsible for the color.
AI_CONTROL_VISUAL_STYLE.2960685;4276545;6776679;16176031 | AI_CONTROL_VISUAL_STYLE_EX.1513239;3026478;3026478 | AI_CONTROL_VISUAL_STYLE_FLAT. | AI_COLOR_DISABLED_TEXT.3026478
However i cannot understand what the numbers after them mean.
Does this .2960685;4276545;6776679;16176031 = Black?
Thank You for your Support.
Best Regards,
Diego.
Re: Dialog Button/Combos Background Color
Hello Diego,
Indeed, to achieve what you need you should just set at install time the "AI_CONTROL_VISUAL_STYLE" property. Please take a look on our "How do I change this color?" forum thread which debates the same topic.
