mustafa
Running .bat file before lunching application
Hi dears,
I'm new to Advanced Installer. After Installing the file setup, I need to run a ".bat" file before running my ".exe" file every time. I found to add it, setting it's attributes as (Hidden, Vital and System), but I need to run it every time before lunching the application.
Please help me, Thanks
Re: Running .bat file before lunching application
Hi and welcome to our forums.
In order to achieve this you can add that BAT file in the "Files and Folders" page of your project, then go in the "Custom Actions" page and add a "Launch file" custom action which will run the BAT file after the "Install Execution Stage -> Finish Execution" action group.
mustafa
Thanks for quick response,
As you said, I added the .bat file to File and Folder, then added a Custom Action, File Launch with this format "[#run_server.bat]", but still no file opens with this. Please let me know where the problem is.
Thanks.
mustafa
And here is another question,
The user that installs my application, every time that opens the file, can this ".bat" file been run before running the main file?
I'm not sure why that BAT file does not run when you install the application. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
I'm afraid that the BAT file will run before your application only when it is installed, not when the user double-clicks the main file. To achieve this you need to modify your application, so that it will launch the BAT file by itself.
