Hi Matthias,
The Operating System does not support CAB files larger than 2 GB. In order to overcome this, you have the following options:
1. Use the "Multiple Volumes" option from the "Builds" page as suggested in the "
The maximum size of a file in a CAB file" thread.
2. Create more features in the "Organizations" page and set the "One CAB archive per feature" option available in "Builds" page
3. Use the "LZMA compression" option as described in the "
Create setup with files larger than 2 GB" thread.
