ArieSmit
Where can I find the Analytics page in Advanced Installer
Hello all,
I can't see a tab for the analytics in the advanced installer software, where is this located?
See attached picture.
I also checked the add-remove at the lower left of the screen but could not locate it their either.
It is a VSTO application.
tnx
arie
Re: Where can I find the Analytics page in Advanced Installer
Hi Arie,
Please keep in mind that the "Installer Analytics" feature were included in version 12.0 of Advanced Installer. So in order to be able to add the "Analytics" page in your project you need to use the 12.0 version of Advanced Installer or newer.
ArieSmit
hello Eusebiu,
thx for the info, we didn't know that :).
Now for upgrading we need the license key but we are unabe to locate this (my collegue went through his older mails, but without luck sofar), any other way to get this?
regards
Arie
Hi Arie,
Please send me an email to support at advancedinstaller dot com with some details about the company and the person that license was registered under, so I will try to find the key in our database and send it to you.
