topher1120
Jenkins Plugin build variables
I'm building a simple installer in Jenkins, and would like to use build variables as part of the version and package name, but can't seem to get them working. Specifically, I'd like to use SVN_REVISION as part of the version and part of the package name.
From the plugin documentation for the "Additional Commands" section, it states:
You can use build variables through the syntax ${VAR} or $VAR. E.g. SetVersion x.x.x
I have the Advanced Installer Jenkins plugin installed and configured. In the "Additional Commands" section, I've added "SetVersion 1.1.${SVN_REVISION}", the build fails with
The version format is incorrect.
Looking at this, it appears that SVN_REVISION is not being interpolated, but I'm not sure why. If I change the line to "SetVersion 1.1.1", it builds fine.
I am using Advanced Installer 13.0 Freeware on Windows Server 2012 R2.
What am I missing to make this work?
Re: Jenkins Plugin build variables
This may happen if the related build parameter (e.g. SVN_REVISION) is not defined for the current build. Can you please make sure the following option is checked in your build configuration:
"This project is parameterized" and that the "SVN_REVISION" parameter is correctly defined?
Let us know if this helped.
