MLiss@Cetrus.com
How do I programmatically set values in Updater project
I like your product... very good stuff... My installation is working great... now I would like to automate more of it.
Specifically, I am using the Advanced installer updater and I would like to know how to programmatically set the following (from my build server):
<Tab page> : <value>
Properties : Main URL
Update Installer : File Path
Update Installer : Product Version
Update Installed Detection : Expected Value
Release Notes : Description
( see attached screen shots )
Re: How do I programmatically set values in Updater project
Hello Mike,
Thank you for your positive words about our application.
I'm afraid we do not have support to update these fields. We added this improvement on our todo list and hopefully it will be available in a future version of AI. Thank you for your suggestion. We will update this thread when the update will be available.
For this you can use our dedicated "/SetInstalledDetection" command line support.
For this you can use our dedicated "/SetUpdateDescription " command line support.
Hello Mike,
Starting with our latest Advanced Installer version (13.1), released today - 19 July, 2016, we have added support to set the Update Installer Tab settings using the "/SetInstallerProperties" command.
