this is my first try in building a desktop application, usually everything runs on a linux server (servlet, and tomcat servlet engine) .
now I have a project that must run on a windows system, it can run manually in DOS if I set the classpath:
set CLASSPATH=c:\program files\myApp\lib\myApp.jar;c:\program files\myApp\lib\servlet.jar
and then
java com.myApp.desk.MyApp
it is not something I can ask my custommers to do, so I need a way to create a windows installer, this software seems perfect.
but I cannot get it to work properly, I created all the folders to place my JAR files, the installer works, copy the jars in the good folders, the start menu shows the link to the exe file, using my own designed icon.
but when I try to lauch the application, nothing happends, I made many tries in the "java product" section, the "Main Class" should be correct, when I enter an other value than "java com.myApp.desk.MyApp" I get a message "could not find the main class .."
I tried to change the JVM parameters (-Xms64M -Xmx256M) force the JRE version to 1.4
so everything seems fine, but nothing happends, I couldn't find any log files (I'm only used to server developpement on linux machine, where there is a log for everything)
any help will be highly appreciated.
