robertvermaa
How to bundle softwares?
I want to create a installer which download setup files from url link then launch it.... but in installation wizard i want checkbox if a user want to install software then click check box or accept.... or don't want to install then uncheck or decline.... every software i want to add terms and conditions tos.... so he/she can accept or decline the software.... I want to bundle approx 4-5 softwares..... how can i do that?
Re: How to bundle softwares?
You can easily achieve this by adding the related setup files as feature-based prerequisites configured to be URL-based. Then, you can create a custom feature selection dialog which will let the user set the install state of your product features. When a feature is set NOT to be installed, then its associated feature-based prerequisite will be skipped from installation.
robertvermaa
thanks for your reply... is there any tutorial for that step-wise-step? or video tutorial so i can easily understand and create the installer...
Just add your prerequisites as feature-based and then simply follow the "Show a custom feature selection dialog" article steps.
robertvermaa
i tried to do this but getting issue...
prerequisites properties:
DialogBox:
please tell me where is my issue....
Please note that when your are using our predefined "Prerequisites" dialog, there is no need to add any custom event on it. Can you please proceed like this:
1. delete the current "PrerequisitesDlg" from the dialogs chain
2 . select "WelcomeDlg" and from its context menu use the "Add Dialog" option to add the "PrerequisitesDlg" dialog again
3. rebuild and test your installation project
Let us know if this helped.
robertvermaa
showing blank no options showing
This may happen if the prerequisite item was not configured to be installed on your current OS version. Can you please go to "Prerequisites" page, select your prerequisite item, go to its "Install Conditions" tab and make sure that in "Supported Windows Versions" section all Windows versions are selected?
Let me know if this helped.
