MLiss@Cetrus.com
purchased installer but getting trial message
I have purchased a copy of advanced installer, but I am getting the following message after I upgraded to 13.1
Can you please clarify what is happening?
Mike
Re: purchased installer but getting trial message
Hello Mike,
Can you please open Advanced Installer and go to "File menu -> Help -> About" and see if the application is indeed in trial mode? If so, can you please register again the Advanced Installer application?
Once registered, every Advanced Installer is bound to the current machine hardware configuration and Windows version. If one of the above changes the license will become invalid and you will have to register it again.
Also, if you create and build a project type higher than you current license edition level (e.g. you have an Enterprise license, but you create and build an Architect project type), then the Advanced Installer application will also revert to trial mode automatically. You can check the project type of the current project opened in Advanced Installer from "Home ribbon tab -> Options -> Project Type tab".
Let us know if this helped.
