vandanayesoji
Issue faced in creating registry Keys using installer
Hi Colleagues,
Greeting of the day!
I have used Advanced Installer to create an addin.
In this particular addin, we have created few registry keys. these registry
keys are related to VSTO.
When we try to run the VSTO, they get the error saying"
System.Deployment.Application.InvalidDeploymentException: Exception reading
manifest from
file:///C:/Program*********ExcelAddon.vsto:
the manifest may not be valid or the file could not be opened. --->
System.Deployment.Application.InvalidDeploymentException: Manifest XML
signature is not valid. "
We are facing few issues after installing this addin in few machines. The
reason being the required registry keys are not getting created. We have added these keys in installer(Attached screen shot for more info)
When we manually add these in the system, the VSTO runs sucessfully and
there addin works.
Can you please suggest why this issue can happen? From our end everything
looks proper.
Is it that the installer is having some issues and so these registry keys
are not getting created or it is because we are missing some thing?
Looking forward for you reply
Thanks & Regards,
Vandana M Yesoji
Re: Issue faced in creating registry Keys using installer
Hello Vandana and welcome to our forums,
This may happen on a 64-bit machine. Please note that by default on a 64-bit machine a registry is created under the 32-bit registry location (Wow6432Node) as long as its component from "Organization" page is not marked as a "64-bit component".
You can go to "Registry" page, select the registry value you have created and from its context menu choose "Go To Component" option. Then check the "64-bit component" flag for the selected component in "Organization" page. Then rebuild and test again the setup project.
Let us know if this helped.
