elou
SetupTypeGroup has wrong Background
in my Setup Dialog I'm using the SetupTypeElement to choose between "custom" or "default" configuration.
When I'm starting the installer from the bootstrap,
everything looks ok.
but when I start from the MSI file
, the component take another background color, so that the text information could not be easily read anymore (see attached screendumps).
How can I bring the MSI setup to show the text as it could be read?
regards, Éric.
Re: SetupTypeGroup has wrong Background
Hi Éric,
Please take a look on the "Why are my dialogs and controls not displayed correctly" FAQ which explains why this problem appears.
elou
Thanks for your replay Eusebiu,
Could tell me how could I use another Text Color for the Text Field when it runs in MSI Mode?
I do not realy understand why the text of the radio buttons is correctly switch to black in the MSI Mode, but not the Text in the label.
Regards, Éric.
Hi Éric,
As mentioned in the link I suggested, these controls cannot be displayed correctly by an MSI package and I'm afraid that the text color cannot be changed when the MSI package is installed. This is the way Windows Installer can display those controls and they can be displayed correctly only by the bootstrapper.
