Hi Everyone,
I'm a newbie to Advanced Installer, just trying to get my head around how it works.
I've created an installer using the trial and it does everything i need it to do. So not sure if this is a restriction of the trial version.
I have followed the video online to create the MSP patch file, but unsure what i am doing wrong.
Firstly the original installer is removing the installer from the systems temp folder after the install, not sure why but the MSP file is looking for the original installer in the designated path when it goes to update and run the MSP file.
Secondly, all i am really updating is a executable file (application executable), my dilemma is, can you use the actually build number that increments IE: 1.0.1.x (where the x is). I have to use the release section of the build number which means i need to manually set this in my development tool. All i want the patch file to do is update the installed executable and the version number in the control panel.
Thank you for your help in advance.
Trevor.
