Parimal Patel
How to Start SQL Server Agent service
Hi
We just purchased licence.
As part of my installation process, How to Start SQL Server Agent service using Advanced installer and set property Start Mode to 'Automatic' ?
Re: How to Start SQL Server Agent service
We do not have predefined support for this, but you can try to use a custom action to start the SQL Server Agent service. Maybe you can find a way to start it automatically through a custom action.
For example, in the attached sample we changed the StartupType of the asp net service in a Power Shell command line custom action.
A sample project is attached to this thread, so if you are interested to take a look directly at my project, you are more than welcome to download the ZIP file. In the sample project, the aspnet_state service is set to start automatically.
Let me know if that helped.
Process ASP Net State - Sample.zip
(3.65 KiB) Downloaded 320 times
Parimal Patel
Hi Dan
Thanks for reply. I will try and let you know.
