Parimal Patel
Setting launch condition and Prerequisites
Hi
Company just purchased the licence and i am trying to achieve following.
I want to set following condition. It could be Launch condition or Prerequisites condition. If i can see both than it's great.
  • 1) SQL Server 2012 R2 + Enterprise Edition
    2) SQL Server 2012 R2 + installed with Integrated Services
    3) SQL Server Agent service must be running
    4) 7-zip
    5) IIS 7.5 +
    6) .Net Framework 4.0
    7) User must have Administrator Privileges
    8) User must have Launch and Activation Permission & Access Permissions in Componet Services -> Computers -> DCOM Config
Re: Setting launch condition and Prerequisites
Hi Parimal,
In order to achieve what you want you can use the support from the "Launch Conditions" and "Prerequisites" page.
You can add some predefined launch conditions from the "Software" tab or you can create your own launch conditions in the "Custom" tab as explained in the "Set launch conditions" tutorial.
Also you can add the predefined prerequisites from the "Packages" section of the "Prerequisites" page or you can add your own prerequisites as explained in the "Add Prerequisites" tutorial.
Parimal Patel
Thanks for reply
I can set .Net Framework 4.0 and .Net Framework 4.5 as Prerequisites. But how can i set .Net Core as a Prerequisites (due to one of the .net component has been developed using .Net Core).
Hi Parimal,
In order to add your own prerequisite (i.e. ".Net Core") you can follow the steps from the the "Add Prerequisites" tutorial.
