MLiss@Cetrus.com
Search Path using property name as directory
I have an installer that worked under the 13.0 version of advanced installer, however under the 13.1 advanced installer, the "search path" is installing my binaries under the NAME of the search path.
I have attached the installer aip for your inspection.
Here is a snap shot of what occurs during the install.
HI install path.PNG (438.79 KiB) Viewed 3493 times
HardwareInventory.zip
(27.13 KiB) Downloaded 269 times
Re: Search Path using property name as directory
Hello Mike,
Can you please make sure the related registry search succeeds? Please manually check before installation the related "Path" registry value and make sure it contains a proper path. If so, please forward us a verbose log of the installation too.
MLiss@Cetrus.com
Found the issue.
Our tester was installing a 3.1 release on a 3.0 install.
Close this please
Hello Mike,
I'm glad you solved this.
Have a nice day,
