a.guelle
[solved] ComboBox shows "Value" instead of "Text"
if I configure a ComboBox where the Control Data Value is different from the Text, it shows a weired behaviour.
Is there a way to only show the Text?
Angelo
Re: ComboBox shows "Value" instead of "Text"
Hi Angelo,
In order for the text to be displayed instead of the value you can select that combobox and set the "Combo List" attribute to "True" in the "Properties" pane.
a.guelle
Works like a charme,
Thank you.
Re: [solved] ComboBox shows "Value" instead of "Text"
You're welcome Angelo. I'm glad I could help.
