twenty94470
Add Key, don't use path
I try to create registry key with the panel "Registry"
I select "Add key from registry" and select my registry key.
But, the path is not the same and add only the key
I need to write all key or import reg...
I would like to know if it's voluntary ? Because in my mind when i want to add key i want all path ...
Or it's possible to have an option "Save all path" or something like that ?
Re: Add Key, don't use path
I'm afraid that we do not have predefined support for this. However, I added this improvement on our TODO list and it will be available in a future version of Advanced Installer. Thank you for your suggestion.
