redzion
Contact: Website Facebook Skype Twitter YouTube
Converting from .EXE to .AppX
I got info how to convert or add new build option beside of default .exe, so that I get also .appx output.
Info link:
http://www.advancedinstaller.com/window ... pdate.html
OK, must say that this is working OK, but I have one problem.
There is no option in .appx which .exe will start as "Run after installation", so in my project it start the wrong .exe file. It start the first .exe by the alphabetic order, what is not OK for me.. I need to set option which .exe is default. Also, there is missing button "Close" after install - if this is even possible in .appx.
Also there is problem, that I can not change icon in .appx project.
Thank you for your answer..
PS. I use Standard edition of AI, if you need project file please tell me..
How to change icon..
Run after install - wrong .exe...
redzion
Re: Converting from .EXE to .AppX
Another problem..
AppX file is no good for Microsoft Windows Store.
Where I can change the error values?
I'm afraid that there is no predefined support for these options yet. We will update this thread when any of these options will be available.
The "Control Panel" icon available in the "Product Details" page will be used by the APPX package.
You can see a response to this question on the "AppX file is no good for Microsoft Windows Store" thread.
