redzion
Contact: Website Facebook Skype Twitter YouTube
AppX file is no good for Microsoft Windows Store
Where I can change the error values?
redzion
Re: AppX file is no good for Microsoft Windows Store
AppX is made from .EXE, so it's just added new build option, but it's not good for MS Windows Store.. But I can not edit manifest file - is there any option to do that?
The AppX package you generated contains the correct schema and manifest entries, required for Win32 (not UWP) applications packaged this way.
Currently Microsoft states the following: Your app's installation experience is much smoother for your customers. You can deploy it to computers using sideloading (see Sideload LOB apps in Windows 10), and it leaves no trace behind after being uninstalled. Longer term, you'll also be able to publish your app to the Windows Store.
You can sideload your AppX on a machine that has the Anniversary Update installed and test it there, until Microsoft opens up the store for submissions.
