kumarkiranc
update INI from dialog window?
I need to update a ini file with the text entered in the dialog window
can u plz help me out how to do that?
thanx in advance
srinivas
Cosmin
Advanced Installer has an INI editor. Using it you can specify the action that is taken when a key is created and also you can insert references to properties as value for a key.
You can read more here:
http://www.advancedinstaller.com/user-g ... files.html
cosmin
kumarkiranc
only default vaue is coming not updating
Thanks for ur early reply. But it is not updating the ini file.
First I add new section.
Name of New Section is Printer.
I add new entery for section Printer.
Key - IP Address
Value - [Main_IP_Add]
Action - Create or Update
In Dialog window
Name of textbox is "txtIPAddress"
Property of TextBox is "Main_IP_Add"
Default value is "192.168.1.5"
When installing i changed the IP address in Textbox. But its showing default value only its not updating the ini file.
Kiran
Cosmin
You must use public properties in order to get information from dialogs and use it.
Therefore you must use MAIN_IP_ADD instead of Main_IP_Add.
You can read more about this here:
http://msdn2.microsoft.com/en-us/library/Aa370912.aspx
cosmin
kumarkiranc
Its Working
Thank You Very Much. It sloved my problem.
