adam555
Command line interface question
I have small problem here.
I need to deploy the Advanced Installer files to Microsoft Azure in order to edit and build projects via command line.
Is there possibility to do so without installation (I cannot install it, its virtualized environment with no user access, i can only upload files via ftp and then use them in code).
I tried to copy-paste the files to other virtual machine with user access (to verify if its possible) and it gave me error - see attached.)
Thanks a lot.
Re: Command line interface question
I'm afraid this is not possible. This is because, aside the resource files, there are also installation components which consist in services, registries, custom actions etc. which are not compatible with Windows Azure.
adam555
Thanks Daniel.
I decided to switch to virtual machine with user access and install it manully and it works as expected.
Maybe you will consider doing a Portable version of AI in future :)
You're welcome. Maybe we'll consider such an improvement (portable AI) in the future. Thank you for your suggestion.
