jrahma
Appdata not installing
I have an app to be installed on Windows Server 2008. The setup has files to be copied to the AppData folder but it's not being copied.
What's the problem here?
Jassim
Re: Appdata not installing
Hi Jassim,
I'm not sure why you encounter this problem. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
