Andrew
Can't Get Why .Net Framework Prerequisite Not Included in EXE
Hi.
The issue is in topic.
Using the following options I expect my EXE-installer must have offline installer of .Net Framework inside. But it doesn't.
What I missed?
Thank you.
Re: Can't Get Why .Net Framework Prerequisite Not Included in EXE
Hi Andrew and welcome to Advanced Installer forums,
I have tested your scenario but I can not reproduce it.
Please note that you can extract the resources inside the .EXE setup package using the following command line:
<path_to_exe> /extract
Let me know if a .NET Framework 4.0 directory is created next to the .EXE file containing the installation package of the .NET Framework 4.0 Client Profile after you run the above command line.
